Problem with SXG75
Problem with SXG75
Diskutiere Problem with SXG75 im English Discussion Forum Forum im Bereich BenQ-Siemens Forum; Hello, I hope that somebody can help me. During new FW uploading on my Siemens SXG75, my mobile just switched out… Now I can not ...
Ergebnis 1 bis 7 von 7
  1. #1
    Problem with SXG75
    Now I can not switch it on any more, although battery is O.K. Is there any special command or procedure to switch it on again?
    Thanks!
  2. #2
    Ex-Admin / mobil-talk.de
    Xperia X1, SL10D
    1.03.932.6 (R2AA006) / 07
    Vista Ultimate SP1
    Moved your posting to the english forums.
  3. #3
    Alien-Fleischfresser
    CX65,S65,S68,S75,2x SXG75 black & white,2x EF81,2x EL71 black & silver,2x E71 black & dark silver
    aktuelle
    XP
    Thanks!
    i had the same problem. just start the updatesoftware again. in my case it just resumed where it broke up and finished the job fine. connect the mobile deactivated. you only need to push the power switch once when your software is searching for the mobile. then the update resumes.
  4. #4
    EF81 SXG75 EL71 S68 A31 S4 Power
    Thanks!
    on every update the mobile switched off and after a few seconds on again, thats part of the updateprogramm. So in this time you sould not diskonekt ne pohne otherwise it will take damage by the software, than you have tou restart tehe phone by a special procedur and with a special update version.
  5. #5
    aktuelle
    XP
    in my case the official update did a fine resume job
  6. #6
    Themenstarter
    Hello, unfortunately I did not manage to fix my problem....
    Thanks for help!
  7. #7
    Themenstarter
    Hell again,
    Can you help me concerning this "special restart and special update version?
    Thanks in advance
Problem with SXG75
Ähnliche Themen zu Problem with SXG75
  1. Testbericht Siemens SXG75: Das Siemens SXG75 dürfte seit der letzten CeBIT sicherlich das meisterwartete Mobiltelefone vom inzwischen neuen Unternehmen BenQ Mobile sein. Mit...
  2. Navigation mit dem SXG75: Das SXG75 besitzt einen eingebauten GPS-Empfänger, der von der mitgelieferten Navigations-Software von VDO (mehr Information zum eingesetzten System...
  3. Navigation: SXG75 vs. S75 m. GPS BT-Modul: Hallo zusammen, ich bin gerade in der Entscheidungsfindung zwischen dem SXG75 und dem S75 und bitte Euch hinsichtlich der Navigation mit dem S75...
  4. Gibt es auch zufriedene SXG75 Nutzer?: Hallo allerseits, ich hoffe ihr verzeiht mir meinen etwas provokanten Threadtitel. ;) Wenn man sich durch das Software- und das Hardwarforum...
sxg75 change language
Stichworte
