dann rentiert es sich wenn der Kofferraum voll wird, brauch ich nur einmal nach München in den OEZ AppleStore
Hatte vorhin noch vergessen den Code zu schreiben: PPT004
https://support.apple.com/de-de/HT203747
Am iMac ergab der Hardwaretest keinen Fehler
EtreCheck version: 2.9.5 (255)
Report generated 2016-02-20 15:00:09
Download EtreCheck from
http://etrecheck.com
Runtime 2:19
Performance: Excellent
Click the [Support] links for help with non-Apple products.
Click the [Details] links for more information about that line.
Problem: No problem - just checking
Hardware Information: ⓘ
iMac (27-inch, Mid 2010)
[Technical Specifications] - [User Guide] - [Warranty & Service]
iMac - model: iMac11,3
1 2.8 GHz Intel Core i5 CPU: 4-core
4 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
2 GB DDR3 1333 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
Empty
BANK 1/DIMM1
Empty
Bluetooth: Old - Handoff/Airdrop2 not supported
Wireless: en1: 802.11 a/b/g/n
Video Information: ⓘ
ATI Radeon HD 5750 - VRAM: 1024 MB
iMac 2560 x 1440
System Software: ⓘ
OS X Mavericks 10.9.5 (13F1603) - Time since boot: less than an hour
Disk Information: ⓘ
ST31000528AS disk0 : (1 TB) (Rotational)
EFI (disk0s1) <not mounted> : 210 MB
Macintosh HD (disk0s2) / : 799.35 GB (594.38 GB free)
Recovery HD (disk0s3) <not mounted> [Recovery]: 650 MB
Test (disk0s4) /Volumes/Test : 198.70 GB (198.40 GB free)
Recovery HD (disk0s5) /Volumes/Recovery HD [Recovery]: 650 MB (624 MB free)
OPTIARC DVD RW AD-5680H ()
USB Information: ⓘ
Apple Computer, Inc. IR Receiver
Apple Inc. Built-in iSight
Apple Internal Memory Card Reader
Apple Inc. BRCM2046 Hub
Apple Inc. Bluetooth USB Host Controller
Gatekeeper: ⓘ
Mac App Store and identified developers
Kernel Extensions: ⓘ
/Applications/Parallels Desktop.app
[not loaded] com.parallels.kext.hypervisor (11.1.2 32408 - SDK 10.9 - 2016-01-15) [Support]
[not loaded] com.parallels.kext.netbridge (11.1.2 32408 - SDK 10.9 - 2016-01-15) [Support]
[not loaded] com.parallels.kext.usbconnect (11.1.2 32408 - SDK 10.9 - 2016-01-15) [Support]
[not loaded] com.parallels.kext.vnic (11.1.2 32408 - SDK 10.9 - 2016-01-15) [Support]
/Library/StartupItems/ArcanaStartupSound/Resources
[not loaded] arcana.PRAM (6.1 - 2012-11-07) [Support]
/System/Library/Extensions
[not loaded] com.sony.driver.prs (1.0.1d1 - 2016-02-20) [Support]
[not loaded] com.wdc.driver.1394HP (1.0.7 - 2016-02-20) [Support]
[not loaded] com.wdc.driver.USBHP (1.0.6 - 2016-02-20) [Support]
Startup Items: ⓘ
ArcanaStartupSound: Path: /Library/StartupItems/ArcanaStartupSound
Startup items are obsolete in OS X Yosemite
System Launch Agents: ⓘ
[failed] com.paragon.NTFS.notify.plist (2014-10-31) [Support]
[loaded] 152 Apple tasks
[running] 32 Apple tasks
User Login Items: ⓘ
Reader Library Launcher Programm (/Library/Reader Library/Reader Library Launcher.app)
iTunesHelper Programm (/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Other Apps: ⓘ
[running] com.brother.utility.NETserver.9712
[running] com.brother.utility.USBserver.31888
[running] com.etresoft.EtreCheck.247488
[running] com.sony.ebook.readerlibrarylauncher.9184
Internet Plug-ins: ⓘ
iPhotoPhotocast: 7.0 (2014-12-21)
FlashPlayer-10.6: 20.0.0.306 - SDK 10.6 (2016-02-20) [Support]
QuickTime Plugin: 7.7.3 (2016-02-20)
Flash Player: 20.0.0.306 - SDK 10.6 (2016-02-20) [Support]
Default Browser: 537 - SDK 10.9 (2014-10-03)
Google Earth Web Plug-in: 7.1 (2013-10-07) [Support]
JavaAppletPlugin: 14.9.0 - SDK 10.7 (2012-06-17) Check version
Safari Extensions: ⓘ
WOT (2015-12-25)
Scroll To Top (2014-09-22)
Open in Internet Explorer (2016-01-15)
3rd Party Preference Panes: ⓘ
Flash Player (2016-01-29) [Support]
ArcanaStartupSound (2012-11-07) [Support]
Time Machine: ⓘ
Mobile backups: OFF
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 799.35 GB Disk used: 204.97 GB
Destinations:
Data [Network]
Total size: 3.00 TB
Total number of backups: 79
Oldest backup: 11.02.14 22:52
Last backup: 07.02.16 13:16
Size of backup disk: Excellent
Backup size 3.00 TB > (Disk size 799.35 GB X 3)
Top Processes by CPU: ⓘ
5% fontd
1% mdworker(2)
1% WindowServer
1% mds_stores
0% kernel_task
Top Processes by Memory: ⓘ
395 MB kernel_task
160 MB softwareupdated
119 MB CVMCompiler(3)
119 MB mds_stores
57 MB Finder
Virtual Memory Information: ⓘ
2.00 GB Free RAM
1.99 GB Used RAM (1.12 GB Cached)
0 B Swap Used
Diagnostics Information: ⓘ
Feb 20, 2016, 02:55:03 PM Self test - passed
