Manuelles flashen der Firmware & S^3 Modding / Verbesserungen C6-01, C7, E7, N8
Diskutiere Manuelles flashen der Firmware & S^3 Modding / Verbesserungen C6-01, C7, E7, N8 im Nokia Symbian 3 Forum Forum im Bereich Nokia Forum; Manuelles flashen der originalen N8 Firmware! ->...
Tigger007
USP-Guru & Ex - Mod
08.07.2009
Stadthagen
Habe ich auch!^^
Windows 8 Pro 64bit
-> http://www.usp-forum.de/nokia-n8-forum/63571-nokia-n8-firmware-manuell-flashen-anleitung-links.html auch für C6-01, C7,E7
Hiermit könnt ihr euer Smartphone anpassen ohne zu Hacken!
Im Anhang eine Google-Übersetzung
S^3 Multiple Mods v7.00 Released (USE AT YOUR OWN RISK!!!)
UPDATE Version 7.0 -> Download
For Mods #01,#02 ONLY select 1 option, if multiple options selected the top most option will be use.
01. KS Type A Improvement Recommended!
- Improve on Kinetic Scrolling, original mods from previous version now your list will be easier/faster/longer on kinetic scroll (you wil SURE feel the different).
02. KS Type B Improvement
- Improve on Kinetic Scrolling, NEW KS mods from PimpJuice mods which make the kinetic scrolling very fast and won't slow down (credit to PimpJuice's mods).
03. UI Improvement - Experiment Mod Recommended!
- Improve UI responsiveness, mods been fine tuned, changed the default FPS from 67FPS to 72FPS and max processing power from 75% to 90% (credit to faenil's mods).
04. Camera Sound Mute Recommended!
- Enable the camera sound to be mute when warning tone been turn off.
For Mods #05,#06 ONLY select 1 option, if multiple options selected the top most option will be use.
05. N8 Continuous AutoFocus Recommended!
- You will have an EXTRA option under Video Setting that enable the Continuous AF during video.
06. E7/C7 Video Mods
- Mods for E7/C7/C6-01 video, enhance zoom steps and increase night mode FPS.
For Mods #07,#08,#09,#10,#11,#12,#13,#14,#15,#16 ONLY select 1 option, if multiple options selected the top most option will be use.
07. N8 Pic/Vid (100/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 100/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.
08. N8 Pic/Vid (097/30FPS)
- Photo quality change the compression ratio from original 85/75/60 to 97/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.
09. N8 Pic/Vid (095/30FPS) Recommended!
- Photo quality change the compression ratio from original 85/75/60 to 95/85/75, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.
10. N8 Pic/Vid (097/25FPS)
- Photo quality change the compression ratio from original 85/75/60 to 97/85/75, video remain 25FPS with capture audio quality will change from 128kbps to 256kbps.
11. N8 Pic/Vid (085/30FPS)
- Photo quality remain as original 85/75/60, video will change from 25FPS to 30FPS and the capture audio quality will change from 128kbps to 256kbps.
12. E7/C7 Pic/Vid (100/30FPS)
13. E7/C7 Pic/Vid (097/30FPS)
14. E7/C7 Pic/Vid (095/30FPS)
15. E7/C7 Pic/Vid (097/25FPS)
16. E7/C7 Pic/Vid (085/30FPS)
17. Photo Gallery Folders Recommended!
- Photo Gallery Folders excluded lots of folders path (please take note some of the folders path are hardcoded to be scan and can't be excluded from listing).
18. Music Gallery Folders Recommended!
- Music Gallery Folders excluded lots of folders path (please take note some of the folders path are hardcoded to be scan and can't be excluded from listing).
For Mods #19,#20, ONLY select 1 option, if multiple options selected the top most option will be use.
19. Browser's Cache (D:\)
- Change the default browser cache folder from C: to D: and set the amount to 32MB, actual effects need those HEAVY internet users feedback.
20. Browser's Cache (E:\) Recommended!
- Change the default browser cache folder from C: to E: and set the amount to 32MB, actual effects need those HEAVY internet users feedback.
For Mods #21,#22,#23, ONLY select 1 option, if multiple options selected the top most option will be use.
21. Start/Shut (C:\Animations)
- Redirect the phone to look for the Startup.gif and Startup.mp3 during startup in C:\Animations folder and look for the Shutdown.gif and Shutdown.mp3 during shutdown in C:\Animations folder. If none are found then the phone won't play any startup/shutdown animations at all.
22. Start/Shut (E:\Animations) Recommended!
- Redirect the phone to look for the Startup.gif and Startup.mp3 during startup in E:\Animations folder and look for the Shutdown.gif and Shutdown.mp3 during shutdown in E:\Animations folder. If none are found then the phone won't play any startup/shutdown animations at all.
23. Start/Shut (F:\Animations)
- Redirect the phone to look for the Startup.gif and Startup.mp3 during startup in F:\Animations folder and look for the Shutdown.gif and Shutdown.mp3 during shutdown in F:\Animations folder. If none are found then the phone won't play any startup/shutdown animations at all.
24. Start/Shut Vol 90% Recommended!
- Increase the Startup/Shutdown default volume from 40% to 90%.
25. Voice Recorder (12H/256kbps/Stereo) Recommended!
- Set the default Voice Recorder to high quality recording (from 64kbps to 256kbps) and increase the max duration of the recording clip from 60mins to 720mins.
26. Music Player Volumn/Heap Mods (100%/32MB) Recommended!
- Experiment mods, no significant effect after the mods.
27. Context Data Object Maximum Size Mod Recommended!
28. Light Sensor Disable
- Totally disable the Light Sensor, LCD will have 100% brightness all the time (will dim ONLY in power safe mode)
29. Haptics Improvement Recommended!
- Lower the vibration and fine tune level 1/2/3 haptics feedback (not must different as i can tell)
30. Vibration Alert Improvement Recommended!
- Same goes with haptics mods, can't really feel big different
31. Camera Full Shutdown (RAM) Recommended!
- Camera apps will fully shutdown once you close the apps (won't remain in the memory), but the N8 have better camera apps as the total shutdown and without only make ~1Mb ram saving (not like what we see in 5800xm as it's camera apps are memory *****)
32. Message Full Shutdown (RAM)
- Message apps will fully shutdown once you close the apps (won't remain in the memory), no significant RAM saving and not sure it will causing others conflict or not (use at your own risk!).
33. Logs Full Shutdown (RAM)
- Logs apps will fully shutdown once you close the apps (won't remain in the memory), no significant RAM saving and not sure it will causing others conflict or not (use at your own risk!).
34. Calendar Full Shutdown (RAM)
- Calendar apps will fully shutdown once you close the apps (won't remain in the memory), no significant RAM saving and not sure it will causing others conflict or not (use at your own risk!).
35. Clock Full Shutdown (RAM)
- Clock apps will fully shutdown once you close the apps (won't remain in the memory), no significant RAM saving and not sure it will causing others conflict or not (use at your own risk!).
36. Contacts Full Shutdown (RAM)
- Contacts apps will fully shutdown once you close the apps (won't remain in the memory), no significant RAM saving and not sure it will causing others conflict or not (use at your own risk!).
37. Fast Screen Rotation Recommended!
- Can feel "a bit" faster but not lighting fast as the delay seem not from the sensor but rather from the UI.
For Mods #38,#39,#40,#41 ONLY select 1 option, if more then 1 option selected NOTHING will be install.
38. N8 FM Transmitter RDS Recommended!
- The FM Transmitter now send RDS "Nokia N8" and not just "Nokia".
39. E7 FM Transmitter RDS
- The FM Transmitter now send RDS "Nokia E7" and not just "Nokia".
40. C7 FM Transmitter RDS
- The FM Transmitter now send RDS "Nokia C7" and not just "Nokia".
41. C6-01 FM Transmitter RDS
- The FM Transmitter now send RDS "Nokia C6-01" and not just "Nokia".
42. Video Call FPS Improvement Recommended!
- Slightly change the video call setting fps from original min/norm/max of 5/10/15 to 10/15/20. Not tested as not really use video call.
43. Database Max Record Count Recommended!
- Experimental mod, Increase database from 20 to 50.
44. HWRM Process Priority Recommended!
- Experimental mod, Hardware sensor priority change from background to foreground.
45. Music Player Equalizer Recommended!
- Add in additional 10 EQ presets, Flat/Speech/Enhance/Treble booster/Bass & Treble/ZigZag/Half-V/Full-V/Half-A/Full-A
EQ Presets Overview
For Mods #46,#47,#48, ONLY select 1 option, if multiple options selected the top most option will be use.
46. Auto Landscape/Portrait Screen
- Add in lots of apps (>500 apps) UID into the default apps orientaion to follow the hardware accelerometer sensor.
(not all apps will follow as not all of them are follow the cenrep configurations, won't work for the Call Screen)
47. Permanent Landscape Screen
- Add in lots of apps (>500 apps) UID into the default apps orientaion to be in Landscape and disable the accelerometer sensor within the setting.
48. Permanent Portrait Screen
- Add in lots of apps (>500 apps) UID into the default apps orientaion to be in Portrait and disable the accelerometer sensor within the setting.
(not all apps will follow as not all of them are follow the cenrep configurations)
49. Charger Note Disable Recommended!
- Disable the Charger notification note.
50. PwrSave Note Disable Recommended!
- Disable the Power Saving mode notification note.
51. Camera Digital Zoom Recommended!
- Enable the dafault camera apps to have Digital Extended Zoom capability.
52. Max Volume Recommended!
- Change most of the apps default volume setting to 100%.
53. Voice Recognition Improvement Recommended!
- Experimental mod, change the default Voice Recognition sensitivity and accuracy.
54. Default Profiles Fix Recommended!
- Enhance all profiles default setting, add in extra "In Office", "Driving", "Church", "Sleeping" profiles (useful if you have Nokia Situation installed)
(This mods changed all profiles able to "VIBRATE" although in Power Saver mode, but the mods will be reset IF you re-trigger the Power Saver manually ONCE)
55. Battery Level Fix Recommended!
- Change the default battery indicator from 100>70>50>40>30>20>10 to 100>80>65>50>35>20>10
(This mods only for eye candy, no real changes regarding the devices NON-Linear battery indicator behaviour)
56. Popup UI Improvement Recommended!
- Experimental mod, change the default Popup UI delay.
57. XCAP Cache Increase Recommended!
- Experimental mod, increased the XCAP Cache size.
58. Critical System Apps Recommended!
- Experimental mod, included RAMBlow, PocketSensor and PocketLock UID into the critical system apps list.
Changelogs:
v7.00
- PR 1.0, PR 1.1, PR1.2 compatibility
- New default camera apps Digital Extended Zoom capability enable
- New individual selectable for Critical Apps fully shutdown mods
- New screen orientation lock mods, all with extra >500 apps UID included
- New default Profiles fix, included extra profiles setting
- New KS Type B from PimpJuice mods
- New Startup/Shutdown volume mods
- New mods to disable the Charger and Power Saving notification note
- New Video FPS only mods included
- New E7/C7/C6-01 FM Transmitter RDS mods
- New multiple default apps max volume mods
- Included extra EQ setting (Half-V,Full-V,Half-A,Full-A)
- Fine tuned the UI Improvement mods and included Popup UI delay changes
- Some others extra experimental mods for testing purpose
v6.00
- Mods now compatible through out all S^3 devices, N8, E7, C7 and C6-01
- Changed mods title
v5.00
- PR 1.0 and PR 1.1 compatibility
- Fine tune some of the mods to add stability
v4.00
- Bugfixes for Video gallery scan folder
- Extra EQ presets (lovely effects)
eace:
- Voice recorder duration changed to max 12 hours recording (can record for whole day event)
- Fast screen rotation mod now only reduce it's sensor timing without changing it's original tilting setting
v3.30
- Included lots of Symbian S60V5 Cenrep mods
v3.00
- Included multiple choices during installation
- Clean up most of the code within the cenrep files
- All mods change back to .cre for better performance
For CAF setting below the recommendation of usage:
1. For close up object (10cm~1m) enable the CAF.
2. For normal video capture (>30cm) disable the CAF.
Just download the attachment and sign it with your cert then install. No hacked phone needed!!
Installation steps:
1. Download the attachment.
2. Sign the . sis with your own cert.
3. Run the signed . sis.
4. Select the mods that you like to install.
5. REBOOT the phone.
Uninstall the mods:
1. Use normal uninstall apps method.
2. REBOOT the phone.
3. All will back to original state.
Modify or Re-select the mods:
Update mods version:
1. Use normal uninstall apps method to uninstall the old mods.
3. Run the signed up-rev .sis.
Credits to the following modders/users for their efforts to make this multiple mods packages a reality:
Szakalit for the sources of EVERYTHINGS!
Faenil for the original H2O mods (the possibility of un-hacked installation)!
CODeRUS for the S60V5 cenreps documentations!
NP for the S60V5 cenreps documentations!
jnx_r for solutions on the installation bugs!
TrinityAlex for discovering the Startup/Shutdown mods typo error!
Quelle: 【2011-02-24】New S^3 Multiple Mods v6.00 (No Hacked Phone needed)
Tipp: http://www.usp-forum.de/nokia-symbian-3-forum/72320-s-3-hack-per-app.html
  • Google Übersetzung.txt
  • sklchan S^3 mods v6.00.zip
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
S^3 Modding/Verbesserung C6-01, C7, E7, N8
Ich habe alles installiert und alles funzt prima :D
Tigger007
USP-Guru & Ex - Mod
08.07.2009
Stadthagen
Habe ich auch!^^
Windows 8 Pro 64bit
Ich auch! Was ich aber nicht ganz verstehe ist CAF für Bilder unter 10cm!? Was muss man da einstellen?
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
Ich denke unter 10 cm wird net gehen, af ist von 10 bis 60cm geignet, ansonsten ausschalten
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
genaugenommen:
Tigger007
USP-Guru & Ex - Mod
08.07.2009
Stadthagen
Habe ich auch!^^
Windows 8 Pro 64bit
Ja aber wo ausschalten? Ich habe den CAF doch nur unter Video!?
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
achso ja nur für video
04. N8 Continuous AutoFocus
aber per nahaufnahme gehts ja ziemlich nah ran, nur halt net mit autofocus, zumindest keinen live sichtbaren
Tigger007
USP-Guru & Ex - Mod
08.07.2009
Stadthagen
Habe ich auch!^^
Windows 8 Pro 64bit
Ahh!
Und was hatt es mit 02. UI Improvement - Experiment Mod auf sich? Das kann ich nun gar nicht verstehen! Warum von 67FPS auf 60FPS?
Wo kommt denn der Wert her? Und was für eine Prozessleistung?
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
vermutlich wurde so mehr leistung freigelegt und man sieht den unterschied ehh net
p.s. die prozessleistung des ui (symbian) wird auf 95% erhöht
Ollie
19.10.2009
Borsfleth
Windows 10
Tigger007
Moin- nachdem ich auf download geklickt habe und dann den download dort vollziehen wollte-meldete sich AntiVir mit Alarm von Malware und der gesamte PC stürzte ab. Habe da sGanze dann nochmal versucht- dann ging es.
Tigger007
USP-Guru & Ex - Mod
08.07.2009
Stadthagen
Habe ich auch!^^
Windows 8 Pro 64bit
Ohh! Welchen Host hast du benutzt? Ich habe über Rapidshare geladen und mein Avira blieb still! Ist ja nur eine Winrar mit einer *sis
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
mein antivir meldete nüscht und nix stürzte ab hmm
Tigger007
USP-Guru & Ex - Mod
08.07.2009
Stadthagen
Habe ich auch!^^
Windows 8 Pro 64bit
Habe die Datei jetzt mal mit angehangen im 1# und als Download eingefügt!
rocky7
08.01.2011
Wie installiere ich es?
und kann Mann es evtl. wieder sauber deinstallieren?
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
wie jede andere .sis datei auch, und man kann es dann genauso wieder deinstallieren
Ollie
19.10.2009
Borsfleth
Windows 10
jo auch rapidshare-ganz normal Standard Download- keine Ahnung warum AntiVir das meldete-bin dann unetr "entfernen" gegangen- danach lief es dann korrekt weiter. Habe eben nochmal aus deinem Beitrag 1 neu downgeloadet. Ok
rocky7
08.01.2011
Wenn ich es installiere, kommt folgende Fehlermeldung:
Zertifikatfehler. Bitte wenden Sie sich an den Programmlieferanten.
Tigger007
USP-Guru & Ex - Mod
08.07.2009
Stadthagen
Habe ich auch!^^
Windows 8 Pro 64bit
D u musst es halt signieren! Benutze zu dem Thema die Suchfunktion!
codi74
16.02.2011
Berlin
Nokia N8
win7 64 bit
habs jetzt 4 tage am laufen und kann nichts negatives berichten, alles nen bissl flotter und ne coole camera :D
padrinoX
10.06.2010
Nokia C6-01 Silver (PC: 059C1C7)
V012.006.02.01
Punkt #31 wundert mich etwas. Denn gerade mit dem Patch habe ich Kontakte, Uhr und Kalender direkt nach dem Booten im Hintergrund laufen.
Ist das bei Euch nicht so?
Dann hatte ich einmal, das nur die Menutaste geleuchtet hat, aber rot und grün waren aus. Aber keine Ahnung womit das zusammen hing.
CU,
Mario
Manuelles flashen der Firmware & S^3 Modding / Verbesserungen C6-01, C7, E7, N8 - Ähnliche Themen
Versandkostenfrei aus DE Original XIAOMI MI Band 3 Smart Wristband,€33.99: ♦ 0.78 Inch OLED Touch Screen: Bigger screen, fit the width of the wrist, bring pleasant feeling of wearing. Big screen display a comprehensive...
Apple mit offenem Brief zur "iPhone Bremse" - Schadensbegrenzung: Apple sieht sich offenbar nun zum Handeln gezwungen...nnDie "iPhone Bremse" war gerade Thema bei uns und ganz offensichtlich bewegt Apple dieses...
Apple bezieht Stellung zu den rassistischen Ausschreitungen in Charlottesville: Apple, Statement und Konsequenzen zu den Ausschreitungen in Charlottesville.nnIn Charlottesville, Virginia, kam es vor einigen Tagen zu...
Samsung Galaxy S3 Mini i8190 Custom Rom: Omni Rom Android 5.1.1: Original Thread: http://forum.xda-developers.com/galaxy-s3-mini/orig-development/rom-omnirom-gt-i8190-s3-mini-t2969867 Bitte dort auch Post #2...
[ROM][G920F/I][7MAY] XtreStoLite Deodexed Mod Edition 1.1 [458MB°Super Debloated°]: Original XDA Thread: http://forum.xda-developers.com/galaxy-s6/development/rom-xtrestolite-deodexed-mod-edition-1-0-t3094423...
nokia e7 hack
nokia e7 flashen
nokia e7 hacken
nokia e7 mod
, nokia n8 flashen, nokia e7 modding, nokia n8 mod, n8 flashen, nokia n8 firmware, nokia c7 firmware, nokia c7 equalizer, e7 hack, nokia c6 flashen, nokia e7 cracken, e7 hacken, e7 flashen, f, verbesserung n8, Nokia n8 equalizer, s^3 modding, nokia n8 mods, nokia c7 modding, Multiple Mods symbian, nokia e7 hacks, nokia e7 firmware
