[ROM] AOKP - Android Open Kang Project - CyanogenMod9 - Android 4.0.x
Diskutiere [ROM] AOKP - Android Open Kang Project - CyanogenMod9 - Android 4.0.x im Samsung i9000 Galaxy S Custom Rom / Mod Forum im Bereich Samsung i9000 Galaxy S Forum; Was ist AOKP?! Features: Android 4.0.3 -- ITL41F Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad...
Mr. Green
Was ist AOKP?!
Features:
Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad (tenderloin, etc)
Unsecure boot.img (stock AOSP kernel)
Superuser & Busybox preinstalled
Deodexed
180 Degree rotation
Built in performance/init.d configuration (Thanks Kejar & company)
Custom Power Menu
Brightness slider in navigation bar.
Custom color for anything in RC
Custom Clock Color/Location: Right, Center, Disable
Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
Nav Bar Transparency
Nav Bar Button Reorder: Back-Home-Search-Menu
Nav Bar Color Picker
Nav Bar Button Glow Duration: Off, Fast, Slow
Nav Bar: Long press to Search button
Nav Bar Hide on Lockscreen
Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
'Traditional' toggle layout (where the toggle are on the very top) -- find in RC > Statusbar General > Layout
LCD Density (Careful with this)
Menu Button location: Right, Left, both, Remove
Menu Button Visability: Always show, Always show Invisible Icons
Lockscreen Style: Stock, Quad, Octo, ol' gingerbread
Lockscreen Wallpaper
Lockscreen color changer
Lockscreen calendar
Lockscreen SMS customizable shortcut (with icons)
Lockscreen Horizontal Option
Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
Unlock Sceen with Legacy Menu Icon
Volume Key to Wake Screen
Volume Key to Skip Tracks
Long-press back button to kill process
Disable CRT off animation
LED pulse settings (time on/off)
ICS ringtones/notification sounds
Customize carrier text to whatever.
Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
Facebook contact sync integration (must wipe to get this)
Disable Boot animation
Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
Long press home for recent apps (thanks brucekey)
Quick torch (enable in ROMControl, long press power when phone turned off. See the magic.)
Fast charge toggle for maguro/toro for kernels that support it
Weatherpanel in notification drawer
Weather on lockscreen
  • Nandroid-Backup
  • Sehr zu Empfehlen: wipe data/factory reset in recovery - Absolut zu Empfehlen wenn Du von einer anderen Rom oder AOKP 4.0.3 kommst
  • Flash ROM
  • Flash Gapps
  • Neustart
Quelle und Downloads: Klick
WICHTIG: Das USP-Forum entzieht sich jeglicher Verantwortung, da das Modifizieren/Flashen seines Gerätes immer ein gewisses Risiko birgt, und somit auf eigene Verantwortung geschieht!
[ROM] AOKP - Android Open Kang Project - CyanogenMod9 - Android 4.0.x - Ähnliche Themen
Neuer DFU Mode iPhone 7/Plus: Habe das heute im Netz gefunden mit dem neuen DFU Mode fürs neue iPhone 7/Plus Mal sehen, ob das dann so ist, am Home Button hat sich ja was...
[ROM]-[S6.G920F] VN™ROM-S6-G920FXXU1AODI-V3.0-Full Deodex-Aroma Install Online: Installationsanleitung und Download Links findet ihr im XDA Thread.
[ROM][ODE][07/05]AllianceROM G920F-Alliance Settings - Lite Available - Update 1: We are not responsible for anything that may happen to your phone as a result of installing custom roms and/or kernels. you do so at your own risk...
[ROM][G920F/I][7MAY] XtreStoLite Deodexed Mod Edition 1.1 [458MB°Super Debloated°]: Original XDA Thread: http://forum.xda-developers.com/galaxy-s6/development/rom-xtrestolite-deodexed-mod-edition-1-0-t3094423...
[ROM][G920F/I][22APR] XtreStoLite Pure Edition 1.0a [662MB°Super Debloated°]: Original XDA Thread: http://forum.xda-developers.com/galaxy-s6/development/rom-xtrestolite-pure-edition-1-0-beta-1-t3082467...
aokp i9000
i9000 aokp
samsung galaxy s2 aokp
battery circle mod aokp
, samsung galaxy i9000 android 4.0, aokp gt p7501, open kang project i9000, aokp gt-p7501, aokp battery, galaxy nexus carrier circle mod, sgs android aokp jb gt-i9000, i9000 aokp jb Rom, galaxy s2 aokp 4.1.1 mod, cyanogenmod 10 navigation bar, p7501 original kernel, cm 9 pershoot circle mod, kies mit aokp, transparent navbar 4.0.4, touchpad aokp jb download, gt p7501 ics custom rom, original aokp kernel 4.1, cyanogenmod9 p7501, usp-forum.de aokp rom für das galaxy tap 10.1n p-7501, galaxy s2 ics circular battery icon mod, Android 4.0.4 galaxy lockscreen animation
