[ROM] AOKP - Android Open Kang Project - CyanogenMod9
Diskutiere [ROM] AOKP - Android Open Kang Project - CyanogenMod9 im LG P990 Optimus Speed Root / Rom Forum im Bereich LG P990 Optimus Speed Forum; Was ist AOKP?! Features: Android 4.0.3 -- ITL41F Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad...
Mr. Green
Was ist AOKP?!
Features:
Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad (tenderloin, etc)
Unsecure boot.img (stock AOSP kernel)
Superuser & Busybox preinstalled
Deodexed
180 Degree rotation
Built in performance/init.d configuration (Thanks Kejar & company)
Custom Power Menu
Brightness slider in navigation bar.
Custom color for anything in RC
Custom Clock Color/Location: Right, Center, Disable
Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
Nav Bar Transparency
Nav Bar Button Reorder: Back-Home-Search-Menu
Nav Bar Color Picker
Nav Bar Button Glow Duration: Off, Fast, Slow
Nav Bar: Long press to Search button
Nav Bar Hide on Lockscreen
Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
'Traditional' toggle layout (where the toggle are on the very top) -- find in RC > Statusbar General > Layout
LCD Density (Careful with this)
Menu Button location: Right, Left, both, Remove
Menu Button Visability: Always show, Always show Invisible Icons
Lockscreen Style: Stock, Quad, Octo, ol' gingerbread
Lockscreen Wallpaper
Lockscreen color changer
Lockscreen calendar
Lockscreen SMS customizable shortcut (with icons)
Lockscreen Horizontal Option
Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
Unlock Sceen with Legacy Menu Icon
Volume Key to Wake Screen
Volume Key to Skip Tracks
Long-press back button to kill process
Disable CRT off animation
LED pulse settings (time on/off)
ICS ringtones/notification sounds
Customize carrier text to whatever.
Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
Facebook contact sync integration (must wipe to get this)
Disable Boot animation
Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
Long press home for recent apps (thanks brucekey)
Quick torch (enable in ROMControl, long press power when phone turned off. See the magic.)
Fast charge toggle for maguro/toro for kernels that support it
Weatherpanel in notification drawer
Weather on lockscreen
  • Nandroid-Backup
  • Sehr zu Empfehlen: wipe data/factory reset in recovery - Absolut zu Empfehlen wenn Du von einer anderen Rom oder AOKP 4.0.3 kommst
  • Flash ROM
  • Flash Gapps
  • Neustart
Quelle und Downloads: Klick
WICHTIG: Das USP-Forum entzieht sich jeglicher Verantwortung, da das Modifizieren/Flashen seines Gerätes immer ein gewisses Risiko birgt, und somit auf eigene Verantwortung geschieht!
aokp p990
aokp lg p990
aokp rom lg optimus speed
aokp p990 forum
, lgp 990 rom, optimus speed aokp, p990 kernel installieren, p990 best custom rom, lgp 990 beste roms, lgp990 aokp, notification bar p990, lg p990 android 4.0 custom rom download, lg p990 best kernel, cm10 für lgp990, lgp 990 rom 4.0, lg p990 android 4.0 custom rom, funktioniert aokp_p990 rom =, p990 kang, lg optimus speed aokp, aokp build 41 p990, open kang project p990, fastest lg p990 rom, root p990 ohne pc, lg optimus p990 android 4.1, p990 stock status bar
[ROM] AOKP - Android Open Kang Project - CyanogenMod9 - Ähnliche Themen
  • [ROM] AOKP Android 4.2.1 Nexus 4
    [ROM] AOKP Android 4.2.1 Nexus 4: Aktualisierungen, Downloads und weitere Informationen im Original-Thread: [ROM] [4.2.1] AOKP :: jb-mr1 :: build-2 :: mako - xda-developers...
  • [ROM](Unofficial) AOKP Nexus 10 Android 4.2.1 JellyBean
    [ROM](Unofficial) AOKP Nexus 10 Android 4.2.1 JellyBean: Aktualisierungen, Downloads und weitere Informationen im Original-Thread: [ROM] AOKP Nexus 10 (Unofficial) Task650 & Ktoonsez (12-4) -...
  • [ROM] AOKP - Android Open Kang Project - CyanogenMod9 - Xoom Wi-Fi
    [ROM] AOKP - Android Open Kang Project - CyanogenMod9 - Xoom Wi-Fi: Was ist AOKP?! Features: Android 4.0.3 -- ITL41F Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad...
    [ROM] AOKP - Android Open Kang Project - CyanogenMod9: Was ist AOKP?! Features: Android 4.0.3 -- ITL41F Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad...
