[ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds
Diskutiere [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds im Samsung Galaxy S2 Custom Rom / Mod Forum im Bereich Samsung Galaxy S2 Forum; Original XDA-Thread: [ROM][GT-I9100][4.0.3] CyanogenMod 9 nightly builds - xda-developers CyanogenModis a free, community built, aftermarket...
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #1
Mr. Green
CyanogenModis a free, community built, aftermarket firmware distribution ofAndroid 4.0 (ICS), which is designed to increase performance andreliability over stock Android for your device.
#include<std_disclaimer.h>
  • Your warranty is now void.
  • I am not responsible for bricked devices, dead SD cards, thermonuclear war, or you getting fired because the alarm app failed.
  • Please do some research if you have any concerns about features included in this ROM before flashing it!
  • YOU are choosing to make these modifications, and if you point the finger at me for messing up your device
  • I will laugh at you.
  • Submitting bug reports on nightly builds is the leading cause of male impotence.
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community.
It can be used without any need to have any Google application installed.
Linked below is a package that has come from another Android project that restore the Google parts.
CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
All the source code for CyanogenMod is available in the CyanogenMod
Github repo. And if you would like to contribute to CyanogenMod, please visit out Gerrit Code Review. You can also view the Changelog for a full list of changes & features.
KNOWNISSUES
http://teamhacksung.org/wiki/index.p...y:Known_issues
INSTRUCTIONS
Firsttime installing CyanogenMod 9 to your Galaxy S II, or coming fromanother ROM:
- READ FAQs:http://teamhacksung.org/wiki/index.p...sked_Questions
-Make sure you're running a proper working CWM like the one from CM7
-Copy GApps and CM9 ZIPs to your internal SDCard
- Boot intoRecovery
- Flash CM9 zip
- Flash GApps zip
- DO A DATA WIPE/ FACTORY RESET (otherwise your calendar sync will not work)
-Reboot
- Don't restore Apps using Titanium Backup!
Upgradingfrom earlier version of CyanogenMod 9:
- Copy CM9 ZIP to yourinternal SDCard
- Boot into Recovery
- Flash CM9 zip
- Wipecache partition and dalvik-cache
- Reboot
ICS GApps-Download:
HIER
Rom-Download: CyanogenMod Mirror Network - Powered by TDRevolution
Auf was alles zu achten ist könnt Ihr dem Original-Thread entnehmen
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #2
robertrudolf
26.10.2010
Samsung Galaxy S3
[ROM][GT-I9100][CM9 4.0.3] CyanogenMod 9 IceCream Sandwich nightly builds
Ich habe die Rom geflasht wie beschrieben,läuft gut ,habe aber festgestellt dass die externe sd Karte zwar erkannt wird (auch belegte und freie Datenmenge) aber die Daten nicht sichtbar sind und darauf auch nicht zugegriffen werden kann.Ich bin aus den faq nicht schlau geworden d.h.es scheint ein Problem mit der SD Karte zu geben,ich habe aber keine Lösung herauslesen können.Hast du einen Vorschlag ?
Herzlichen Dank rr
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #3
Mr. Green
Ein lang bekanntes und altes Problem bei CyanogenMod, die bekommen es nicht richtig auf die Reihe die Partitionen "anzusprechen".
Navigiere mit dem Root-Explorer deiner Wahl ganz hoch, bis Du im "/"-Verzeichnis (Root) landest, dort solltest Du einen Ordner sehen, "emmc".
Das ist die Externe SD-card.
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #4
robertrudolf
26.10.2010
Samsung Galaxy S3
Habe sie gefunden.Danke für die schnelle Antwort
rr
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #5
arrow
19.11.2009
Habe mal vielleicht eine etwas dämliche Frage, aber wie könnt ihr Apps ohne einen Filebrowser installieren?
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #6
Mr. Green
Lade Dir einen Filebrowser aus dem Play Store!
:D
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #7
arrow
19.11.2009
:D
Und was, wenn man keinen Play Store auf dem Gerät hat?
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #8
Mr. Green
Dann hast Du dir, wie jeder 2te der nicht aufmerksam liest, die Google Apps nicht installiert!
Oben steht eine Anleitung (wenn auch in Englisch), die sehr einfach gehalten ist.
Dort findest Du einen Download-Link zu den GApp's, diese *.zip per CWM-Recovery flashen ;)
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #9
arrow
19.11.2009
Schande über mein Haupt =D.
Mal eine andere Frage die Vibration von den Kapazitiven Tasten ist ziemlich heftig kann man die irgendwo runter drehen?
Habe diese Funktion bis jetzt noch nicht finden können ^^
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #10
Mr. Green
Hast Du Standard-Kernel der beim Rom dabei ist oder einen anderen Custom-Kernel?
Meistens ist diese Funktion vom Kernel geregelt.
Beim Siyah-Kernel kannst Du die Intensität mit "ExTweaks" regeln.
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #11
P-Yeah
P-Yeah
09.12.2011
Niedersachen
Samsung Galaxy S 2
Windows 7 Ultimate x64
Da muss ich sagen weiß ich auch selbst nich was damit so gemeint ist..? Eine App? Zusatzeinstellung im Menü?
Danke!
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #13
arrow
19.11.2009
Bin mir nicht sicher ob das so stimmt. Habe den Siyah kernel auf 2 Roms und bei der einen Rom kann man die Vibrationsstärke im Menü einstellen. Deswegen denke ich eher, dass es im CM9 Menü versteckt ist.
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #14
arrow
19.11.2009
Also ich muss sagen die zu starke Vibration geht einem nach einer weil echt auf den Sack.
Habe Extwaks installiert finde jedoch keine Option für die einstellung der Vibrationsstufe...
Gibt es diese Einstellung überhaupt nicht?
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #15
Mr. Green
Sicher doch, siehe Bild:
Nach dem ändern der Einstellungen, wäre es aber zu Empfehlen das S2 neu zu starten damit diese Änderung auch sicher übernommen wird ;)
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #16
arrow
19.11.2009
Ja, diese Funktion habe ich auch schon gefunden nur ist mir die Vibrationsstärker immer noch zu stark bei der Stock kann man es irgendwie noch viel viel schwächer einstellen?
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #17
Mr. Green
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #18
arrow
19.11.2009
Hast Du auch sicherlich den Siyah-Kernel?
Versuche mal folgendes:
Flashe diese Datei per CWM: http://www.usp-forum.de/samsung-galaxy-s2-custom-rom-mod/82738-kernel-cleaning-script.html
Im Siyah-Kernel Recovery-Menü alle "ExTweaks-Einstellungen" reseten.
Anschließend alle Einstellungen neu tätigen.
Muss ich den Kernel auch noch mal Frisch flashen?
Weil es ist alles gleich geblieben... Die Vibrationsstufe verändert sich ja auch nur bei 0 ist sie immer noch ziemlich stark...
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #19
Mr. Green
Nein den Kernel musst nicht neu flashen, einfach mal das Script drüber laufen lassen.
Hast Du den aktuellsten Siyah-Kernel geflasht?
gruß
  • [ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds Beitrag #20
arrow
19.11.2009
[ROM][GT-I9100][CM9 4.0.4] CyanogenMod 9 IceCream Sandwich Nightly-Builds - Ähnliche Themen
Punjabi Turban photo editor HD : sardar style 2021: The best element of this application is that you can attempt Sikh or Sardar turban and you can see which style is suitable for you. you can try...
kode vpn- vpn free unlimited proxy master x: kode vpn is the app where you can use free, secure and unlimited VPN for Android users.you can easily unblock websites , protect your online...
Pathan afghan photo editor HD : Turban style 2021: Pathan afghan photo Editor is the app where you can Use trending turban cap styles stickers and afghan dress photo editor which enables you to...
Android 8.0 / 8.1 frp bypass 30.03.2019: English manual below Hey, Ich bin neu hier und hoffe das ist der richtige Bereich. Ich habe vielleicht einen neuen Weg gefunden Frp zu umgehen...
Versandkostenfrei aus DE Original XIAOMI MI Band 3 Smart Wristband,€33.99: ♦ 0.78 Inch OLED Touch Screen: Bigger screen, fit the width of the wrist, bring pleasant feeling of wearing. Big screen display a comprehensive...
cyanogenmod 9 automatische helligkeit
cm9 automatische helligkeit
i9100 cm9
cm9 i9100
, cyanogenmod sd karte wird nicht erkannt, cm9 helligkeit, cyanogenmod 9 sd karte wird nicht erkannt, sgs2 4.0.4, cyanogenmod 9 vibrationsstärke, cm9 i9100 xda, cm9 sd karte wird nicht erkannt, samsung galaxy s 2 i9100 mit android 4.0.4 ice cream sandwich cm9 , Android 4.0.4 Ice Cream Sandwich CM9 , cm9 sgs2 changelog, cyanogenmod 9 akku schnell leer, cm9 changelog, gt-i9100 cyanogenmod 9, cm9 display helligkeit, cm9 galaxy note changelog, cm9 galaxy s2, cyanogenmod 9 galaxy s2 automatische helligkeit, CyanogenMod 9 - Ice Cream Sandwich 4.0.4, cyanogenmod 9 gt-i9100, samsung galaxy s2 i9100 mit android 4.0.4 ice cream sandwich cm9, cyanogenmod helligkeitsstufen
